DeLorean Battery drain - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 3 - Electrical (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=15) +--- Thread: DeLorean Battery drain (/showthread.php?tid=4072) |
DeLorean Battery drain - mknowlton - 21 Jul 2013 Hi, I am just looking for a bit of advice as I have just returned from holiday to find that my battery has drained over the last fortnight due to a 0.15 Amp drain which was present whilst the ignition was off. I have traced the source of the drain to the dip beam relay being energised although the ignition is off and the lights are not on. Can anyone advise if this is correct for this relay to be always energised as it doesn't seem correct to me? Any advice would be much appreciated. ![]() Mike Re: DeLorean Battery drain - Rich H - 21 Jul 2013 Hi Mike By 'energised' do you mean there is voltage across the coil terminals? It is normal for there to be 12v present on one of the switched contacts. The headlights can be operated with the ignition off. Your power drain is most likely due to the central locking module. It is a poor design and draws quite a lot of current all the time. Try unplugging it... Re: DeLorean Battery drain - MikeWard - 21 Jul 2013 Mike, I would recommend you invest in one of these: http://www.ebay.co.uk/itm/UNIVERSAL-CAR ... 35be3ed62a I always have my battery isolated when not in use, and I've never had any problems with flat batteries. As RichH mentioned, it is most likely the central locking module that's the cause of your issue. If you are handy with a soldering iron the central locking module can be modified to significantly reduce the current draw. Re: DeLorean Battery drain - mknowlton - 21 Jul 2013 Thanks for your replies Rich & Mike It is definitely not the door lock module as I have measured the drain and it reduces to practically zero when I remove the dip beam relay. Just to clarify that yes, when I say the relay is energised with the ignition off I mean that there is full 12 volts across the relay coil thus energising it and closing the contacts but the lights are not on. It is the relay coil alone that is giving the discharge current of 0.15 Amps Thanks Mike Re: DeLorean Battery drain - Chris P - 21 Jul 2013 I agree with Mike, fit a battery isolator....also acts as an additional ant -theft device. Re: DeLorean Battery drain - Rich H - 21 Jul 2013 The dip beam relay coil is fed from the headlight switch via the indicator stalk flasher. If there is a voltage across the coil, but not quite enough to pull it in and turn on the relay, then that suggests there is a partial short circuit somewhere. Alternatively a good old bad earth is responsible for most weird faults... A schematic will help a lot if you don't already have one There's an excellent one here: http://www.cortex.biz/schema/schema_V1.31.pdf Re: DeLorean Battery drain - mknowlton - 22 Jul 2013 That's great, many thanks for your advice guys, much appreciated. Mike Re: DeLorean Battery drain - mknowlton - 23 Jul 2013 Hi, Just to let you know that I located the fault with the battery drain. Referring to the wiring diagram it was apparent that the dip beam relay socket base had been incorrectly wired into the loom (probably during a restoration under a previous ownership). Despite this wiring fault, everything worked OK because the relay was energised at all times and the headlamps were being powered directly via the Headlamp switch and stalk on the steering column rather than through the relay contacts! I have corrected the wiring as per the diagram and everything works fine and there is no battery drain as the relay is not energised with the ignition off. Thanks again for all your help on this guys. Mike |
