Squeaky steering rack? - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: GENERAL DELOREAN DISCUSSION (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=2) +--- Forum: General Discussions on the DOC / Car / Company / JZD (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=25) +--- Thread: Squeaky steering rack? (/showthread.php?tid=4060) |
Squeaky steering rack? - flux3d - 15 Jul 2013 The steering rack, or something at the front of the car seems to be making a fair amount of noise, squeaking every time I move it or turn the wheel. Seems to have gotten a lot worse in the hot weather. I'm thinking of popping the inspection hatch above the rack and taking a peak, but question is what should I use to lube any squeaking areas? Will normal grease work? Maybe blast it with some silicone spray? I have some red grease I've used on my bike, would this be ok to use on the steering rack, or is there a specific product that should be used? Re: Squeaky steering rack? - Nick H - 15 Jul 2013 Have a look at the track rod ends. Maybe a squirt of that silicone spray would be worth a try. Regards Nick H Re: Squeaky steering rack? - Stuart Rees - 16 Jul 2013 When you say turn the wheel, does is squeak when the car moves or only when the steering wheel is turned and the car is stationary? I had a squeak when only turning the steering wheel and it was a dry steering column bush... |
