Throttle microswitch adjustment - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 1 - Engine (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=13) +--- Thread: Throttle microswitch adjustment (/showthread.php?tid=3918) |
Throttle microswitch adjustment - jwrayth - 23 Apr 2013 Another day, another thing to fix After the car has been running for a while (about 15 minutes or so) the car starts to stick in a high idle (around 1800 RPM). Having read online about this issue, I tripped the microswitch on the throttle control and idle returned down to the expected 775 RPM.So I need to adjust my idle screws, not a problem! Using the following as a reference; ![]() I have found my microswitch adjustment screw to be rusted in-place tight, and my idle speed screw to be rusted in to the retaining bolt, but itself moving very loose within the bracket. So my question is; Is it worth cleaning the rust of the bolts and attempting to re-use them or should I look at replacing them? If keeping the originals, how best do you think I can adjust the idle speed screw so it stays tight in the bracket? I haven't found a cross reference or sizing details for them, so if the consensus is to replace then I would greatly appreciate it if someone could share the sizing details so I don't have to attempt to measure it all myself
Re: Throttle microswitch adjustment - Rich Hanlon - 24 Apr 2013 Hmm,. pretty sure it'll be a standard thread, looks like M4 or M5 from here. |
