air filter? - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 1 - Engine (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=13) +--- Thread: air filter? (/showthread.php?tid=3917) |
Re: air filter? - Chris Williams - 23 Apr 2013 viewtopic.php?f=21&t=1071 and viewtopic.php?f=21&t=1807 Chris Re: air filter? - MikeWard - 24 Apr 2013 Oil: Most of use will use either 10w/40 or 20w/50, the choice is yours. Oil Filter: Mahle OC460 http://www.ebay.co.uk/itm/Genuine-Mahle ... 257cb3abae Air Filter Mahle LX689 - http://www.opieoils.co.uk/p-61769-mahle ... fiat-.aspx Or a Bosch filter should be readily available from your local euro car parts store if you prefer: http://www.eurocarparts.com/ecp/c/Fiat_ ... 7cd&000008 Fuel Filter: Bosch 0 450 905 401 http://www.ebay.co.uk/itm/1x-Bosch-Fuel ... 4abc825af9 Plugs: Bosch HR6DC+ http://www.ebay.co.uk/itm/6x-Bosch-Supe ... 35bc65523a Distributer Cap: Intermotor 44030 http://www.ebay.co.uk/itm/INTERMOTOR-44 ... 257d1ccf5d Rotor Arm: Intermotor 47080s http://www.ebay.co.uk/itm/1x-Intermotor ... 2ec2d7dad4 Re: air filter? - Guinney1971 - 24 Apr 2013 its a piece of p*** to service one of these, even I can do it! Re: air filter? - Chris Williams - 24 Apr 2013 Quote:Fuel Filter:Also from same seller Bosch Oil Filter: http://www.ebay.co.uk/itm/221130835520? ... 124wt_1328 Chris Re: air filter? - MikeWard - 24 Apr 2013 FWIW from what I've read online, Bosch oil filters aren't all that hot. Personally I'd stick with the Mahle filter if at all possible. Re: air filter? - Chris Williams - 24 Apr 2013 Quote:FWIW from what I've read online, Bosch oil filters aren't all that hot. Personally I'd stick with the Mahle filter if at all possibleYes I had read the same, but these are made in Germany, not Mexico as the US ones and the same as Ed sells, so should be OK (one would hope :lol: ) However with a Mahle at £6.69 delivered you cant go wrong really! Chris |
