Clutch fork clip position - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 4 - Transmission - Manual & Automatic (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=16) +--- Thread: Clutch fork clip position (/showthread.php?tid=3807) |
Clutch fork clip position - Yianni - 03 Mar 2013 Hi All: When installing the clutch fork into the ball stud, does the clip (spring) go between the ball and lip with dust cover in front of clip or the dust cover behind ball stud and clip behind lip, which is approximatly 5mm back from ball. The manual is not clear on this. Thank you all in advance for your input. Yianni. Re: Clutch fork clip position - stunned_monkey - 03 Mar 2013 The function of the clip is to keep the fork and bearing in place as you assemble it. It doesn't matter where it goes as long as it's behind the ball. I put it behind the rubber bit as well. |
