Idle speed altering when fans cut in - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 3 - Electrical (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=15) +--- Thread: Idle speed altering when fans cut in (/showthread.php?tid=3753) |
Idle speed altering when fans cut in - bjbrownie - 27 Jan 2013 Just curious about this one-when the cars fully warmed up and ticking over at +-950 rpm (it seems happy at this tickover speed), when the fans cut in the rpm drops by about 200- alternators output checked and still at 13.5 ish volts, fans switch off and idle speed goes back to normal, it's always been like this, and yes, I've checked for air& vacuum leaks but none anywhere. Thoughts, anyone? Re: Idle speed altering when fans cut in - stunned_monkey - 30 Jan 2013 When you first start the car, does it rev to about 2000 and immediately drop to idle, and does the idle steadily increase from a cold start? Re: Idle speed altering when fans cut in - bjbrownie - 30 Jan 2013 After going to around 2000 rpm It drops straight down to about 850 ish rpm, and stays there until its fully warmed up- doesn't cut out but idles speed goes up a little to around the 900 mark. Re: Idle speed altering when fans cut in - stunned_monkey - 31 Jan 2013 Are the brass screws backed out at all? Is the throttle closing properly? Sounds like the idle system is working but you have some air bypassing the throttles. Re: Idle speed altering when fans cut in - bjbrownie - 31 Jan 2013 No, all three screws are all the way in, I stripped and cleaned the throttle body a while back, no discernible wear at all (38k), all manifold gaskets replaced at the same time, replaced the V.O.D pipes also while checked the vacuum pipes to the heater valve and servo, all good and tight. I always adjust the throttle with the accelerator connection removed, can't think where air could be getting in, but a good pointer-I'll use soapy water on the connections and see what happens, thanks Re: Idle speed altering when fans cut in - stunned_monkey - 01 Feb 2013 bjbrownie Wrote:It drops straight down to about 850 ish rpm, and stays there until its fully warmed up- doesn't cut out but idles speed goes up a little to around the 900 mark ...and I would bet a good 50p that when your fans kick in, it drops back down to 850. In other words, the idle system is fully closed and the engine is idling on a leak of air (not necessarily a vacuum leak) when the engine is hot - enough air to bring it up to 900rpm with no other load. As soon as you give it more load, like from the alternator, the revs drop to 850 at which point the idle system catches it. Re: Idle speed altering when fans cut in - Guinney1971 - 01 Feb 2013 my 'normal' cars do this, on my old Omega for instance, if you put the heated rear window on (which also heated the mirrors), it would increase load on the electrical system and you'd hear the engine note change and the idle revs drop ever so slightly. Re: Idle speed altering when fans cut in - bjbrownie - 01 Feb 2013 I'll give it a looking at very soon, it's getting warmer and drier! Cant think of where air could be bypassing the throttles but squirting some soapy liquid may reveal an air leak (hopefully )! Re: Idle speed altering when fans cut in - Guinney1971 - 02 Feb 2013 bjbrownie Wrote:it's getting warmer you've not seen next weeks weather forecast then.... Re: Idle speed altering when fans cut in - bjbrownie - 03 Feb 2013 I did Claire, never trust the BBC............ Re: Idle speed altering when fans cut in - Guinney1971 - 03 Feb 2013 bjbrownie Wrote:I did Claire, never trust the BBC............ :lol: :lol: :lol: :lol: How can you tell when a weatherman is lying? His lips are moving :wink: |
