BTTF Car passed MOT but need part - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: OFF TOPIC TALK, BTTF, JOKES ETC (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=3) +--- Forum: Back To The Future (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=61) +--- Thread: BTTF Car passed MOT but need part (/showthread.php?tid=3607) |
Re: BTTF Car passed MOT but need part - Rissy - 17 Sep 2012 ...Is it this you're talking about? http://store.delorean.com/p-8720-axle-boot.aspx (I also don't think you can refer to your car as being "The" BTTF car any more. There is more than one in the UK. - Just a mention) Re: BTTF Car passed MOT but need part - Rich H - 17 Sep 2012 The rear drive shaft gaiters are not an MOT fail, but should be replaced asap to prevent dirt ingress into the CV joint. Ideally if the tear is bad, then the joint should be disassembled, the old grease cleaned out and replaced with new as grit in the joint can damage the bearings. Quniton Hazell: QJB122 Moprod: CVK193 Ford Granada circ. 1981 Re: BTTF Car passed MOT but need part - dmc4087 - 21 Sep 2012 I'd imagine an hour of labour would cover that work (removing driveshaft, dismantling joint(s?), cleaning, greasing and re-installing) |
