fuel pump banjo bolt size? fuel line size? - Printable Version
+--- Thread: fuel pump banjo bolt size? fuel line size? (/showthread.php?tid=3542)
fuel pump banjo bolt size? fuel line size? - dknight - 31 Jul 2012
so im just sorting the missing bits from the delorean, and wondered if anyone off top of their head knows the size of the banjo bolt that goes on the fuel pump? (106976)
also while i am at it what size is the rubber fuel feed/return line? (106979) car is not to hand at the minute so can not check myself
many thanks again!
Re: fuel pump banjo bolt size? fuel line size? - stunned_monkey - 02 Aug 2012
If your pump has a banjo bolt it'll be an M12 x 1.5mm. if you're replacing the pump, you'll get one that needs a domed nut of the same thread,.
Re: fuel pump banjo bolt size? fuel line size? - dknight - 02 Aug 2012
yeah it was a new replacement pump with banjo fitment, cheers for that
Type "bosch fuel pump nut" into google, you'll soon find one. it's a non-standard dome nut, annoyingly.
