fuel tank packing pads? - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 2 - Emission / Fuel Systems (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: fuel tank packing pads? (/showthread.php?tid=3529) |
fuel tank packing pads? - dknight - 20 Jul 2012 i bought a replacement set from ed and i am trying to figure out what bits go where, does anyone have any pictures? bit anal maybe but i would just like to get it right! thanks Re: fuel tank packing pads? - Rissy - 20 Jul 2012 I've only ever taken the cover plate off my car to reveal the underside of the tank, but when i did, there was a triangular section of squashed foam stuff on the cover plate. So i guess a triangular piece goes there. I remember seeing pictures else where, and i'm sure there was two long rectangular pieces, one for each vertical long length down the sides of the tank, and then a shorter one for the back vertical wall of the tank too. I think also, my tank has some "L" shaped foam pieces positioned on the top long edges where you can see a couple when you remove the access panel to see the fuel sender and pump etc. In fact, i've just looked, it shows you here: http://store.delorean.com/c-274-2-1-0-t ... oretc.aspx When I had my cover plate off, I renewed the old triangular pad with some sound insulation foam you would use to pad the inside of the your PC case to lessen the noise. Seems just fine for a bit of padding, and better yet, didn't cost me anything. Was like this sort of stuff, cut to shape with scissors. Had some already, which I never used: http://www.mnpctech.3dpixelnet.com/pict ... iew9z4.jpg (Although I think my stuff looked a bitter more rigged than this. This stuff looks quite soft and squashy. Mine has a bit more sponginess to it.) Re: fuel tank packing pads? - dknight - 20 Jul 2012 cheers for the reply, yeah i have that diagram but i could not figure out form what i had and what that diagram shows, i have seen elsewhere 3 bits packing the front top to add to the confusion: ![]() i have checked what ed sent me and i think i have a rogue set of pads, as they do not look like what should be in the kit, so that should answer that, i will put some pictures up once i have done so at least there will be a record then! Re: fuel tank packing pads? - Rissy - 20 Jul 2012 You should have 11 pads total as noted in the link: http://store.delorean.com/c-274-2-1-0-t ... oretc.aspx To be honest, i'm sure it's not THAT precise. Common sense. It's only for padding to help cushion and stop any potential movement (Even though its a snug fit anyway) Once buttoned up again, no-one sees it anyway. Saying that though, I'm sure since you've paid the money, you want to make sure you have the right pads, and then once you do, I'd say common sense. As for your photo, I think that is simply evidence that the pads like to stick more to the frame compared to the plastic tank. Either that or someone stuck them to the frame INSTEAD of the tank. Just shows you how uncritical it is. |
