Radiator feed and return? - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 1 - Engine (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=13) +--- Thread: Radiator feed and return? (/showthread.php?tid=3475) |
Radiator feed and return? - dknight - 30 May 2012 just wanted to double check which was the feed and return on the radiator? thanks Re: Radiator feed and return? - Rissy - 30 May 2012 Feed TO the radiator is on the Driver's side (TOP of Radiator) Return FROM the radiator is on the passenger side (BOTTOM of Radiator) + a small air lock outlet at the top of the radiator (in most cases, as i think some have removed them...for whatever reason!?) on the same side which joins the same return line back to the expansion tank etc in the engine bay. Re: Radiator feed and return? - dknight - 30 May 2012 cheers mate, i did assume this but wanted to make sure! |
