Crank pulley needed - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 1 - Engine (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=13) +--- Thread: Crank pulley needed (/showthread.php?tid=3347) Pages:
1
2
Crank pulley needed - Guinney1971 - 05 Mar 2012 can anyone help? I need to replace the crank pulley on #2292's engine, Dave H has been trying to sort one for me, but no luck so far, so if anyone can help, please let me know, as my car isnt going anywhere without a new one. Cheers all, Re: Crank pulley needed - dmc4087 - 05 Mar 2012 Sorry Claire I cant help ya, just curious what happened to the old one? Re: Crank pulley needed - Guinney1971 - 06 Mar 2012 it got damaged when the car got rear ended on the way back from a show last year ![]() Can you find out if Keith or anyone else in Ireland can help out? Re: Crank pulley needed - dmc4087 - 07 Mar 2012 I'll certainly ask Re: Crank pulley needed - Guinney1971 - 09 Mar 2012 thanks Thomas! ![]() Re: Crank pulley needed - stunned_monkey - 10 Mar 2012 I'm pretty sure I have one but it needs sleeving. I'm not sure when I'll get a chance to go to my mum's and have a look in the loft though, sorry. They are available form Houston at a price. Have you tried Renault? It's for an R30TX Re: Crank pulley needed - dmc4087 - 12 Mar 2012 Keith doesnt have one. Re: Crank pulley needed - Guinney1971 - 12 Mar 2012 stunned_monkey Wrote:I'm pretty sure I have one but it needs sleeving. I'm not sure when I'll get a chance to go to my mum's and have a look in the loft though, sorry. Yeah, Houston want the best part of $300 for summat the size of a saucer, and thats without shipping and then duty this end, which is a joke. what do you mean by 'sleeving' Martin? No desperate hurry at the mo, Dave Howarth has been trying to get one off an engine for me, but no luck yet it seems. If you can have a look next time your at your mums (say Hi to her for me ![]() Thomas, thanks for asking around mate, much appreciated. Re: Crank pulley needed - dmc4087 - 12 Mar 2012 Is yours badly knackered? Could it be repaired somehow? Re: Crank pulley needed - stunned_monkey - 12 Mar 2012 SKF makes very thin precision ground stainless sleeves for covering over damaged lip seal surfaces - you can get them in all sizes. I know the pulley I'm thinking of has a pitted surface where the seal goes. Speedi-sleeves are available from RS Re: Crank pulley needed - Guinney1971 - 18 Mar 2012 basically, my pulley has a really bad wobble on it when the engine is running, it happened when the car got rear ended last summer, and its getting progressively worse. Gonna ring Dave Howarth again tonight and see if he's had any joy trying to get the one he's got off of the engine he has...... Re: Crank pulley needed - dmc4087 - 21 Mar 2012 They can be tricky enough to remove Re: Crank pulley needed - stunned_monkey - 21 Mar 2012 Ain't that the truth. Air gun and blow torch. Not in that order. Unless you really get angry. Re: Crank pulley needed - Guinney1971 - 23 Mar 2012 I seem to recall when we originally did Flopsy's engine in 2003, you telling me to hold the car in 5th gear and stand on the brakes whilst you hauled on the 'betsy bar' attached to rachet & socket on the pulley nut ![]() Other option is, to take mine off, and get a new one machined by RichH's mate with an engineering workshop. Car's eh.......... :roll: Re: Crank pulley needed - Nick H - 28 Mar 2012 I still have nightmares about removing crankshaft pulley nuts! :wink: After trying and failing with the 5th gear and windy gun . I got a Peugeot diesel flywheel locking tool. Costs about £6. You remove the starter motor and using One of the bolting points, bolt in the locking tool which will mesh with the starter ring gear. Thus the flywheel is locked. Then heat the b###### nut . I found a heavy duty map gas blow lamp (ideal for lighting the BBQ at Le Mans :lol: ) worked a treat. Then use a breaker bar and it will come off. A new nut cost £2 from Renault . They were out of stock so I got mine from Volvo for £8. They know how to charge! If you want to borrow the locking tool I can stick it in the post. Regards Nick H |
