2.7 or 2.8 fuel metering unit? - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 2 - Emission / Fuel Systems (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: 2.7 or 2.8 fuel metering unit? (/showthread.php?tid=3303) |
2.7 or 2.8 fuel metering unit? - bjbrownie - 17 Jan 2012 Just picked up a bargain off ebay, basically the whole injection system and distributor off a Volvo 260 for spares (only£25), and not sure which engine its off-fuel distributor is Bosch 0438 100 035, distributor is part number 0237 402 013- on the metering manifold it has a vacuum intake and a blanked off plug, reading through the various data supplied its fitted to both 2.7 & 2.8 engines. Any ideas? 8) Re: 2.7 or 2.8 fuel metering unit? - Chris Williams - 17 Jan 2012 Good buy (shame I missed it) should bolt streight on, be worth getting the metering head re-cond though. The air intake part will be about 1cm wider (internal size) than a DeLorean and is a much better part to let air in the engine. Chris Re: 2.7 or 2.8 fuel metering unit? - Guinney1971 - 19 Jan 2012 three words Brian................... You Jammy Sod !! lol Good find there mate 8) Re: 2.7 or 2.8 fuel metering unit? - bjbrownie - 19 Jan 2012 Its amazing what you can find on the bay if using the right search criteria Claire-got a brand new(old stock)Volvo waterpump-the bolt on pulley type-for £7.80, p&p was a bit expensive at £3.50! I'm reconditioning the fuel distributor and possibly using the new throttle assembly as well-it even has the original plastic caps over the adjusting screws and the mixture adjustment is still sealed, hopefully its not faulty and was slung in favour of a replacement........... 8) Re: 2.7 or 2.8 fuel metering unit? - stunned_monkey - 21 Jan 2012 Fit the ignition distributor, set advance to 11 degrees. Fit fuel metering head and intake "flap". Re-plumb DeLorean CPR to always "see" engine vacuum and set CO to 2%. You MUST remove your cat converter to use this metering head. Re: 2.7 or 2.8 fuel metering unit? - bjbrownie - 21 Jan 2012 Thanks,I'll do that on re-assembly shortly-my car was de-catted years back, I've just dismantled the unit and apart from being covered in surface oxidisation the internals were remarkably clean-only the metering unit drop valve thingy was stuck, possibly due to petrol residue. Left it soaking in petrol overnight so hopefully it'll free off. 8) Re: 2.7 or 2.8 fuel metering unit? - stunned_monkey - 22 Jan 2012 There's a very good chance you won't be able to put it back together without it leaking, they're famous for that. I free off stuck plungers by putting it in the oven (after removing the ppr o rings). 10 mins at 150 does the trick Re: 2.7 or 2.8 fuel metering unit? - bjbrownie - 24 Jan 2012 Wifes not going to be happy with the metering unit cooking with the roasties...........but I may give it a try with the 'scientific' explanation! Let you know how I get on! 8) :lol: Re: 2.7 or 2.8 fuel metering unit? - Martyn - 04 Feb 2012 It worked though didn't it Mart. Polly will never know :wink: Re: 2.7 or 2.8 fuel metering unit? - bjbrownie - 08 Feb 2012 Cooking metering units to make the valve drop out really works! Nice tip! 8) :lol: |
