Reversing lights repeatedly blowing fuses... - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: GENERAL DELOREAN DISCUSSION (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=2) +--- Forum: General Discussions on the DOC / Car / Company / JZD (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=25) +--- Thread: Reversing lights repeatedly blowing fuses... (/showthread.php?tid=3056) |
Reversing lights repeatedly blowing fuses... - Rich Hanlon - 23 Mar 2011 Morning folks, interesting one this time... Every time I engage reverse (this in on an Auto, by the way), the 10A reversing light fuse (no.16) pops. However, if you then leave the car in reverse, and put a new fuse in, all lights up as normal. Then take it out of R, lights go off ā re-engage, and the fuse pops again. Grrr ā running out of spares!! So far, Iām thinking: 1. Higher rated fuse (can be risky but might try a 15A for trial purposes only 2. Replace the normal incandescent bulbs with LED ones to reduce the current draw. Does anyone have any other ideas/ suggestions/ potential causes? Re: Reversing lights repeatedly blowing fuses... - dmc4087 - 23 Mar 2011 Could the reverse light switch be dodgy? Or are the wires going to it slightly melted on the cross over pipe? Re: Reversing lights repeatedly blowing fuses... - Rich Hanlon - 23 Mar 2011 dmc4087 Wrote:Or are the wires going to it slightly melted on the cross over pipe? Aha! You may just have got it there my good man! I've a vague recollection something got crisped at one stage - you may just be right...! Cheers, R |
