Drivers door issue - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: GENERAL DELOREAN DISCUSSION (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=2) +--- Forum: General Discussions on the DOC / Car / Company / JZD (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=25) +--- Thread: Drivers door issue (/showthread.php?tid=3033) |
Drivers door issue - Mrdashbo - 04 Mar 2011 It seems that my drivers door is a slightly different colour Than the rest of the car. Slightly more champagne colour Just wondering if its grained in dirt or just differences In metal or graining. Any suggestions how to correct this Mike Re: Drivers door issue - Chris Williams - 04 Mar 2011 I'm not an expert on re-graining, but it could be worth cleaning it. I have found Cilit-Bang works really well at getting all the crud off!! Mind you I'm often frowned at for having used it but it did remove hube amounts of oxidisation from my S/Steel ![]() Perhaps best try in an are you cant see first, Chris Re: Drivers door issue - Mrdashbo - 05 Mar 2011 Great I love tips like this thanks Chris, which cilit bang do you use "grime n lime" ;-) Re: Drivers door issue - Chris Williams - 05 Mar 2011 Mrdashbo Wrote:Great I love tips like this thanks Chris, which cilit bang do you use "grime n lime" ;-)Yes :!: worked a treat! especially if you use a scotchbrite pad with the grain. Chris Re: Drivers door issue - Mrdashbo - 05 Mar 2011 Thanks Chris, Which grade scotch brute did you use? |
