Death by valet ! - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: GENERAL DELOREAN DISCUSSION (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=2) +--- Forum: General Discussions on the DOC / Car / Company / JZD (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=25) +--- Thread: Death by valet ! (/showthread.php?tid=2922) |
Death by valet ! - Mrdashbo - 31 Oct 2010 Had my Delorean valeted, during which they steam cleaned under My wheel arches. Now I have a little squeaky sound when I go over bumps or turn the wheel. I assume the steam has melted the grease of key areas. Do these cars have grease nipples under and around the suspension? Or is it just a case of greasing around joints n stuff? Can anyone recommend a type of grease best for the job? Peace! Re: Death by valet ! - Chris Williams - 31 Oct 2010 2 grease nipples on each side of the front suspension on the ball joints of the upper and lower arms, (wheel end) any bearing grease should be suitable. It may be just water sitting somewhere that will dry out (hopefully not in the wheel bearings) Or in the spring mounts which often make a noise! Chris Re: Death by valet ! - stunned_monkey - 31 Oct 2010 It's probably the rubber suspension bushes - spray a bit of silicone grease on their general area. In particular the top of the shock tower and the anti-roll bar bushes |
