Main engine earth braid - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 3 - Electrical (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=15) +--- Thread: Main engine earth braid (/showthread.php?tid=2887) |
Main engine earth braid - Rich Hanlon - 29 Sep 2010 Hi folks, just refitting the engine. One end of the main engine earth braid goes to the engine mounting to body bolts - but can't remember what the other end goes to. Is it one of the starter motor mounting bolts? Or even one of the main engine to bellhousing bolts? Need a little jog of the memory. Thanks team, Rich Re: Main engine earth braid - dmc4087 - 30 Sep 2010 If you mean the strap between the engine and frame - one end uses the stud for the engine mount, and the other uses one of the bolts that holds the engine mount itself to the chassis. Its just to get around the rubber of the mount. Re: Main engine earth braid - Rich Hanlon - 04 Oct 2010 Magic, thanks! |
