WTD - Indicator stalk switch assy - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: GENERAL DELOREAN DISCUSSION (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=2) +--- Forum: DeLorean Cars or Parts For Sale or Wanted (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=26) +--- Thread: WTD - Indicator stalk switch assy (/showthread.php?tid=2738) |
WTD - Indicator stalk switch assy - Rich Hanlon - 10 Jun 2010 Hi folks, does anyone have an indicator stalk switch assembly kicking about? The wire to the horn push has failed in mine - seems to have broken part way up inside the stalk so hopes of a repair are looking slim! I've had a look at the Lucas parts catalogue http://www.lucaselectrical.co.uk/catalo ... 63-119.pdf and the MG Midget 1500n one seems very similar - to P/No. SQB194. Correct connector, correct functions etc. Stalk appears very similar, as does the steering column mounting piece. Anyone have any expereinces of these? DMCH only seem to do stalks as a pair for $105 or thereabouts. Cheers team, Rich Re: WTD - Indicator stalk switch assy - Guinney1971 - 10 Jun 2010 I always thought the DeLorean column stalks were similar to Mini/Metro ones. Worth hunting round Looms' - or mebbe nick the one of your Aggro for now? BTW, did you use those Espace window motors? Mine are fubar
Re: WTD - Indicator stalk switch assy - Rich Hanlon - 10 Jun 2010 Already thought of that - Similar style, same functions, but unfortunately the plug is wired up differently and the attachemnt to the column is completely wrong. Close but no cigar. Lots of ones on that catalogue look similar but have different plugs, functions or column attachmnents - the Mg Midget one seems the closest and sutby different to general Mini/ Allegro ones. I got one Espace motor, the other off a 21 as the Espace had been crushed before I could get back. Same components as the DMC ones, but it would need shortening somehow I think. Also the brackets that hold the glass would also need hacking with the Dremel to make it the same as the DMC ones. I'd say if you've got a set of old ones then you could get a working assembly out of the combination of them. Re: WTD - Indicator stalk switch assy - stunned_monkey - 10 Jun 2010 Hi Richard - as you prolly know they're $104 from the US I have a good second hand set (from the same car your alternator came from actually) if you'd like to make an offer? Re: WTD - Indicator stalk switch assy - Rich Hanlon - 10 Jun 2010 Cheers Marty, PM on its way! Re: WTD - Indicator stalk switch assy - bjbrownie - 15 Jul 2010 The stalk assembly looks very similar to one off a Morris Marina...... 8) |
