volvo 760 crankcase, do i need to change it? - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 1 - Engine (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=13) +--- Thread: volvo 760 crankcase, do i need to change it? (/showthread.php?tid=2638) |
volvo 760 crankcase, do i need to change it? - stu3954 - 03 Mar 2010 Im restoring a D, and it came without the engine, so im putting a volvo 760 engine into it, but noticed the crankcase is different, the engine mounts are different on the 760 crankcase. do i need to get hold of a Delorean crankcase?? Really need some advise please. Re: volvo 760 crankcase, do i need to change it? - Chris Williams - 03 Mar 2010 Basically does it look like a DeLorean engine?? If not it probably is a different later version V6. If it looks like a DeLorean engine you should just need to move over your origional sump and sandwich plate (the bit that sits between the sump and block) and lots of other bits and bobs, including engine mounts and remove/add plugs in the sides of the block for oil pressure stuff. Pictures may help. Chris Re: volvo 760 crankcase, do i need to change it? - stu3954 - 03 Mar 2010 can i email you some pictures? it says on the block that its a B28 engine. Re: volvo 760 crankcase, do i need to change it? - Chris Williams - 04 Mar 2010 stu3954 Wrote:can i email you some pictures? it says on the block that its a B28 engine.Sure no problem, Having done a couple of these swaps now (including my own) there not that difficult to do. Chris Re: volvo 760 crankcase, do i need to change it? - stunned_monkey - 04 Mar 2010 If you haven't got *anything* where the engine should be, you're a bit stuffed, because you need the crank case, sump and all the oil pickup gubbins, plus the flywheel, clutch etc. I have a couple of lower crank cases and several flywheels, but I don't have a sump or the oil pickup spacers spare. I also have an entire running, known good DeLorean engine with 16k miles on it - pm me if interested. Re: volvo 760 crankcase, do i need to change it? - Chris Williams - 04 Mar 2010 Having had a chat on the phone tonight I did not realise you did not have an engine to rob bits from. In this case as Martin mentions it may take time to get all the bits together but probably not impossible! Chris Re: volvo 760 crankcase, do i need to change it? - stu3954 - 06 Mar 2010 Ok Chris, thanks, im sure i will get them somehow, got plenty of time anyway, Thanks for the chat and advise though. Stu |
