METERING HEAD NUMBERING - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 2 - Emission / Fuel Systems (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: METERING HEAD NUMBERING (/showthread.php?tid=239) |
METERING HEAD NUMBERING - Chris Williams - 08 Jan 2007 Hi, Would any one have a picture of diagram of the metering head showing what every hole does? Ie; what feeds which injector etc etc, Only ask as I have replaced the fuel lines with Harveys S/S ones and according to the markings I made I'm correct however looking at his reference photo; http://www.specialtauto.com/delorean-pa ... el-set.jpg I think he/or I may have the l/h bank wrong? Thanks Chris - NickT - 08 Jan 2007 http://www.dmcnews.com/Techsection/fuelhoses.htm enjoy nickt. - bozzzydmc - 08 Jan 2007 I have his fuel hoses too , I cant see what is wrong in his picture, but the one Nick has posted is the one i followed . Anyway the 6 injectors all get fuel at the same time so it wouldnt matter if you 'happened' to get mixed up. Did you go for the new banjo bolts as well ? Also it doesnt matter which way round you get the return line to the tank / frequency valve back onto the double banjo bolt. Found these lines a lot easier to fit in than oem ones.... still fiddly round the ISM area though. - Chris Williams - 08 Jan 2007 Excellent, thanks Nick, It does appear to be incorrect in the photo. I thought it was but allways best to be sure! Chris - Chris Williams - 08 Jan 2007 bozzzydmc Wrote:I have his fuel hoses too , I cant see what is wrong in his picture, but the one Nick has posted is the one i followed . Anyway the 6 injectors all get fuel at the same time so it wouldnt matter if you 'happened' to get mixed up. Did you go for the new banjo bolts as well ? Mike I think he has 4,5 &6 the wromg way round as in 4 is where 6 should be and visa versa! Chris - NickT - 08 Jan 2007 That wouldn't matter as the fuel system isn't sequential 8) 1 to 6 can be put onto any cylinder in theory. While you were at it you could have replaced the fuel injector rubber boots as these can be a source of vacuum leaks. It is the rest of the connections that are critical. Have fun, NickT. - bozzzydmc - 08 Jan 2007 arrh right got you now ... it wouldnt matter but its nice to get them the stock way round ![]() I found the nut on the hose to the rigid return line a right pain to get off. |
