urgent ...can't get the alternator 2 brown wire plug off. - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 3 - Electrical (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=15) +--- Thread: urgent ...can't get the alternator 2 brown wire plug off. (/showthread.php?tid=2343) |
urgent ...can't get the alternator 2 brown wire plug off. - steve.s - 23 Jun 2009 hi all how is this removed tried a screwdriver, pull back the lock clips, just refuses to budge. not sure though how it engages. this is the only thing stopping me removing the alternator. mine is original ducellier, and wanted to get it reconned. however is there in the UK a drop in equivalent with exactly the same wiring?. desperate to get that MOT. thankyou for any help. Regards Steve Re: urgent ...can't get the alternator 2 brown wire plug off. - Tourettes Tony - 23 Jun 2009 the worse thing you can do is snap the connector, me personally would cut it near the connector and work on it away from the car, worse way you only have to solder and heat shrink it TT Re: urgent ...can't get the alternator 2 brown wire plug off. - steve.s - 23 Jun 2009 hi thanks does it somehow unclip? if i undo the 2 screws, does that do it? steve Re: urgent ...can't get the alternator 2 brown wire plug off. - steve.s - 27 Jun 2009 hi bump!. has anyone else done this and left the brown wires intact?. Regards Steve Re: urgent ...can't get the alternator 2 brown wire plug off. - Tourettes Tony - 27 Jun 2009 can you get a pic up here mate TT Re: urgent ...can't get the alternator 2 brown wire plug off. - Rich Hanlon - 13 Jul 2009 Anything that had the alternator upgrade service bulletin carried out would have had this plug snipped anyway. The ones Martin G does still use the brown wire to the positive feed for the alternator on a narrow spade terminal. The other wire (wider spade terminal) goes to the dashboard warning light. If the voltage rectifier has popped on yours then good luck with the recon, I think they're unobtanium :? Re: urgent ...can't get the alternator 2 brown wire plug off. - Dan6457 - 13 Jul 2009 Rich Hanlon Wrote:alternator upgrade service bulletin What was this? Re: urgent ...can't get the alternator 2 brown wire plug off. - Rich Hanlon - 13 Jul 2009 Twas this: http://www.dmcnews.com/bulletins/ST-26-11.81.html Re: urgent ...can't get the alternator 2 brown wire plug off. - Dan6457 - 13 Jul 2009 Cheers Rich I have a motorola on mine from new so nothing to worry about then phew!
