i need to remove my head - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 1 - Engine (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=13) +--- Thread: i need to remove my head (/showthread.php?tid=2272) |
i need to remove my head - tom inman - 30 May 2009 Hello people It's been a while since I've posted on here. Erm been too busy on facebook. Anyway the carbs on, the engine's running, fuel pumps pumping, injectors not injecting, valley of death accessible but and it's a big but I've got a bit of a water leak into one of the cylinders. Don't think it's the head gasket or a crack in the cylinder head, what I do think and I know it's very taxing is that erm, erm is that the waters getting in from a manifold bolt. Tried taking the head off today but I got stuck with the old timing chains and my question is, is it worth fannying around taking all the timing chains off and dismantling the engine to remove the head and try and get it repaired or should I get a new engine, because I seem to have a lot of nuts and bolts all over the garage floor and a limit of my skills has been reached. Your wealth of knowledge, ingenuity and experience is greatly apreciated in this matter. Thank you very much for reading and your responses would be greatly appreciated. Typed by Sally dictated by Tom ps i've added 2 videos of the d on youtube http://www.youtube.com/watch?v=oVZSMvzKIoM http://www.youtube.com/watch?v=VXTPAt_Eg4M Re: i need to remove my head - Rich H - 31 May 2009 Hello matey, long time no speak ![]() Hmm, sounds suspicious...What makes you think it's a manifold bolt? Re: i need to remove my head - Tourettes Tony - 31 May 2009 it does sound suspect, i reckon the gasket has rotted (possibly). personally i would buy a a volvo and butcher it for parts and rebuild the original engine, but thats me. Its a shame your not nearer i would have done it for you Tom TT Re: i need to remove my head - Chris Williams - 31 May 2009 As above, why would you suspect a head bolt?? Much more probably just the head gasket gone, just use a compression tester to check where and which cylinders to narrow it down. So long as you can fix the timing chains in place when you take a head off there not that difficult to do in situ. Chris Re: i need to remove my head - Tourettes Tony - 31 May 2009 I thought that but i spoke to tom and it sounds like someone has tapped out the thread and gone into the water jacket ![]() Re: i need to remove my head - Chris Williams - 31 May 2009 Tourettes Tony Wrote:I thought that but i spoke to tom and it sounds like someone has tapped out the thread and gone into the water jacketWhere in the head or block?? With best salesmans hat on I do have a few (good) DeLorean heads spare ![]() Chris Re: i need to remove my head - Tourettes Tony - 31 May 2009 Its running a volvo engine chris and you cant swap them ![]() Re: i need to remove my head - Nick H - 01 Jun 2009 Could be worth checking the old Volvo scrap yard on the A1. If they have any V6 heads laying about. Lakes Auto's, Wyboston, A1 Northbound, Near St Neots. +44(0)1480 212291 The only really tricky thing I found when doing the head gaskets is removing the pulley nut. You can get a flywheel locking tool for Peugeot diesel engines for under £10. Remove the starter motor and use the locking tool in one of the mounting bolt holes to lock up the flywheel. Then heat up the pulley nut with a decent gas blow torch (the high temp MAPP gas type is good, also great for starting BBQ's :wink: ). It's then easy to remove. Chains are pretty staright forward just follow the manual and line up the marks on the sprokets with the marks on the chains. Renault chains already have the marks. Some replacements don't have the marks but just transfer them (carefully) across with a paint marker. Keep the old chains in a safe place so if you ever have to go in there again you have them for reference. Regards Nick H Re: i need to remove my head - NickT - 01 Jun 2009 I've got a volvo v6 flywheel locking tool if you nee to borrow it. Let me know and I will bring it to eurotec. NickT Re: i need to remove my head - tom inman - 01 Jun 2009 Thanks for all your replies. There's a lot of useful info. It's definatley coming out of the manifold bolt hole. I whipped the spark plugs out and turned it over and there's water pissing out of it. I think I might just pop a new engine in if I can get hold of one and see if I can repair this one later on. Looking forward to seeing everyone at Eurotech to have a chat about it. Cheers Tom Re: i need to remove my head - Chris Williams - 01 Jun 2009 Tourettes Tony Wrote:Its running a volvo engine chris and you cant swap them Ahh, missed that one :roll: Chris Re: i need to remove my head - tom inman - 01 Jun 2009 Tourettes Tony Wrote:Its running a volvo engine chris and you cant swap them IT'S running a volvo engine. I'll have you know she's got a name, Dixie The Reliable!! :lol: |
