Charging / Voltage issue - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 3 - Electrical (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=15) +--- Thread: Charging / Voltage issue (/showthread.php?tid=2257) Pages:
1
2
Charging / Voltage issue - TheOriginalMrP - 26 May 2009 Bit of a new one on me. Voltage gauge has always read about 2-3 needles widths over the 13V when the engine is running, unless of course the headlights / fans/ etc are all on then it will be just above the 13V When i went to monmouth 3 weeks ago, after the 15 mile journey, i noticed on tickover the needle was bang on 13V when idling, but the use of any accessories would make it drop below 13 which it never does. I ignored it, and last weekend i went to start the car after 2 weeks, and it wouldn't turn over. I had to put the other battery on, and then it went fine. On my way to hereford, i noticed it was 13V one minute, just over the next, and a few needles widths above as it should be all at different point of the journey. Aint been back down the garage since, but i got a feeling the alternator is on its way out - either that or the plug is corroded or something, another thing i aint checked. Fan belt could be tighter, but i cant see that being the issue to be honest. Not once though has the charging battery light came on while driving. Any ideas? I think the alternator was re-built about 2002 ish....... can you clarify this ChrisS? I also want to source some braided front brake hoses, cos i think one of mine has collapsed after swivelling it last year. Cheers people...... Ben Re: Charging / Voltage issue - Tourettes Tony - 26 May 2009 new alternator mate, and edd is coming over get a set of hoses off him cheers TT Re: Charging / Voltage issue - bozzzydmc - 26 May 2009 Well I agree Tony... Perhaps Ed can bring over a new Alt too? I can help it to get over to you ..... Re: Charging / Voltage issue - Rich H - 26 May 2009 Could just be the regulator pack thats going down, though they can be rather expensive. Also check for bad connections on the main power cables. The positive makes quite a few jumps around the alternator, starter, battery, starter post and eventually to the bulkhead, just below the coil. Any one of those could be loose or corroded. Also check the battery negative where it bolts to the chassis. It shares one of the mounting bolts of the right hand TAB bush - this is notorious for corrosion and wotking loose. Re: Charging / Voltage issue - bozzzydmc - 26 May 2009 I dont know about tyring to repair old alternators, they just seem to pack up again and you end up spending just as much as a new one ... personally speaking if its a 28 year old one you can do better with a modern higher powered one ... just my 2p worth Re: Charging / Voltage issue - NickT - 26 May 2009 ...and get a decent battery !! NickT Re: Charging / Voltage issue - bozzzydmc - 26 May 2009 Exactly Nick... however im getting worried as Ben is getting more attractive to me every day ..... Re: Charging / Voltage issue - Tourettes Tony - 26 May 2009 yes he has done his hair :lol: TT Re: Charging / Voltage issue - NickT - 27 May 2009 Phew, I thought it was just me ! NickT Re: Charging / Voltage issue - bozzzydmc - 27 May 2009 No need to worry Nick ...your more than enough man for me ![]() Re: Charging / Voltage issue - NickT - 27 May 2009 bozzzydmc Wrote:No need to worry Nick ...your more than enough man for me ...thin ice there Mike ! Re: Charging / Voltage issue - jerzybondov - 27 May 2009 If you've got voltage and alternator issues, just about every possible cause is discussed on this yankee thread: http://www.dmctalk.com/showthread.php?t=13145 Re: Charging / Voltage issue - ChrisS - 27 May 2009 The Alt was replaced by a rebuilt OEM Motorola several years ago. Dave H had it rebuilt for me. I cleaned most of the connections but would check the ground connection on the TAB as previously mentioned as I have not touched that connection. One way to check is to run a 'decent' jump lead from the battery negative onto the engine. Oh and a load test on the battery to make sure that's up to speed. Have you checked the alternator is charging ok? Re: Charging / Voltage issue - bozzzydmc - 27 May 2009 NickT Wrote:...thin ice there Mike ! My apologizes ... should have worded that differently x Re: Charging / Voltage issue - NickT - 27 May 2009 bozzzydmc Wrote:NickT Wrote:...thin ice there Mike ! OK sweetie xxx NickT ps 1 day to go !!!!!!!! |
