 Cooling fan never stops - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 3 - Electrical (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=15) +--- Thread: Cooling fan never stops (/showthread.php?tid=2242)  |
Cooling fan never stops - KMC-DMC - 15 May 2009 The cooling fan on my car is always on. Even if i only turn the ignition to electrics without starting the engine the fans still start. They are noiser than the engine. I guess it would be worse if they didn't start at all! Can anyone point me in the right direction to resolve this problem? Thanks Kevin Re: Cooling fan never stops - Rich H - 15 May 2009 Try disconnecting your otterstat It's fitted in the ally coolant pipe on the left hand side of the engine compartment running along the chassis arm. Sometimes they are bridged out and this causes the fans to run all the time, sometimes the otterstat goes short circuit. Re: Cooling fan never stops - bozzzydmc - 16 May 2009 Is your AC / vent switch turned to on ??? Re: Cooling fan never stops - KMC-DMC - 16 May 2009 Thanks for the advice. I got under the car and disconnected the wires to the otterstat. I cleaned the terminals and now it works OK. Fans kick in only wen temp gets past 150degf and when a/c is running. I'll buy a new otterstat and gasket becasue the current one didn't look too healthy. Kevin Re: Cooling fan never stops - bozzzydmc - 16 May 2009 Otterstat (Rad Fan) Switch VRF311 (Austin Metro)  |
