Outer door seals - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 8 - Frame / Body / Interior (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Outer door seals (/showthread.php?tid=2223) |
Outer door seals - Dan6457 - 05 May 2009 I think I'm going to put new outer door seals on my car and wondered which ones are recommended as being good. Ed's seem a good price, as do John Hervey's, Martin's Silicon ones are the most expensive but are they really worth it? Cheers, Dan Re: Outer door seals - Darren C - 05 May 2009 Hi Dan, I used the DMC ones like Ed's. No Problems at all. In theory Martins should be best, but whoevers you use the final finish is down to the fitting. There's a few useful tips on the forum already so I won't go over old ground. I'd read them through and take your time fitting them to get it right. Regards D PS, put the Scuffmaster in the post to you today, PM me if you need any help/advice on applying it. Re: Outer door seals - Dan6457 - 05 May 2009 Cheers Darren, I might get Ed to bring a set to eurotec then. If they are good enough for you they must be ok :wink: Thanks for the scuffmaster. I'm assuming I can brush it on to get an even coating? Re: Outer door seals - bozzzydmc - 05 May 2009 I have a set on that PJGrady supplied me ... still look great 2 years on .. they do a small and large profile depending upon your door fit... Re: Outer door seals - Darren C - 05 May 2009 Hi Dan, Your better putting it on with a sponge (honest) you can use a small one like a pan scrubber type (just dont use the scotchbrite side :wink: ) then you wont get brush marks. For the flat surface a sponge mini paint roller will do a good even job. The best advice is do it in thin coats not one thick one, and allow it to dry in between. Regards D Re: Outer door seals - Dan6457 - 05 May 2009 Thanks Darren I'll give it a go later this week. Thanks Mike I'll check out their site. |
