Door mirror removal - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 8 - Frame / Body / Interior (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Door mirror removal (/showthread.php?tid=2175) |
Door mirror removal - Dan6457 - 16 Apr 2009 Hi does anyone know how you remove the glass from the door mirrors without breaking it? My passenger one wobbles about so I want to get behind to see whats loose. Dan Re: Door mirror removal - Conor Doyle - 16 Apr 2009 Hi Dan, Use a hair drier to heat the glass, this will soften the adhesive gum that holds the glass on. Conor Re: Door mirror removal - Dan6457 - 16 Apr 2009 Oh blimey, I thought there must be a way of uncliping the whole thing rather than ungluing it :roll: Re: Door mirror removal - Barson - 17 Apr 2009 nope - it's glue ![]() if it's original glue, you should be able to just pry it off wiht your fingers. when i came to remove my mirrors, it was really easy. if they're on properly or have been re-glued, then yeah, hair dryer.
Re: Door mirror removal - Dan6457 - 17 Apr 2009 Oh joy! :roll: Any idea what could be loose or worn inside to make it flop about? Re: Door mirror removal - Barson - 17 Apr 2009 page 17 of this install guide: http://s89196484.onlinehome.us/files/Mi ... ctions.pdf shows two strut things that attach two sides to the rear of the housing. it's possible that one of these struts has come loose. I take it you don't have full control over the mirror. does it tend to twitch when you move it so far? Dave. |
