Rear fascia lower bolts sheared off in middle and bowing - Printable Version
+--- Forum: 8 - Frame / Body / Interior (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=19)
+--- Thread: Rear fascia lower bolts sheared off in middle and bowing (/showthread.php?tid=2082)
Rear fascia lower bolts sheared off in middle and bowing - richard - 27 Feb 2009
Hi Guys,
Just trying to put the rear bumper back on the car, but have noticed that the rear lower bolts, item 4&5 in the figure below have sheared off. They are of course moulded into the plastic section.
Does any one know how to resolve this? The only most secure way i could think of was to drill through, but then you would have bolt heads showing all the way along the rear lower section of the fascia.
Also the plastic itself if bowing the middle a touch, from the exhaust heat. Any ideas on fixes?
[Image: bumper.jpg]
Re: Rear fascia lower bolts sheared off in middle and bowing - bozzzydmc - 27 Feb 2009
Apart from plastic welding some new studs in... maybe bonding a stainless steel strip on with the studs welded on to it ? Perhaps this will help pull your valance straight? Tiger seal would stick this .
Seen a car with these drilled and bolted right through and the heads painted black , its not really that noticable but i would try other methods first.
Re: Rear fascia lower bolts sheared off in middle and bowing - Bandit - 27 Feb 2009
Mine all sheared when I removed it for the frame resto'. I tried a few things, non of which seemed to work. When you think about it, as you drive forward it's almost like a parachute, so the wind force on it must be quite high.
I ended up doing exactly what Bozzy suggested & drilled it, adding small 5mm 'flanged button head' bolts. Looked fine once done.
Re: Rear fascia lower bolts sheared off in middle and bowing - Dan6457 - 27 Feb 2009
A couple of mine sheared too taking the body off :roll: I might get away with just using what I have left, otherwise I'll have to do what Julian's done too.
Re: Rear fascia lower bolts sheared off in middle and bowing - steve.s - 05 Mar 2009
hi
can you not dremel the back and resin bond new studs?
would be a shame to have to drill through.
is there no other protruding plastics you could tie something though to hold also?
or metal strap or something
