Winter Checks - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 1 - Engine (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=13) +--- Thread: Winter Checks (/showthread.php?tid=1946) |
Winter Checks - stevieT - 29 Oct 2008 Hi everyone, This is my first post on the forum as a new (well April) Delorean owner. This will obviously be my first winter with the car and I would just like to check if there is anything I should do - for example, make sure the anti-freeze is topped up, etc etc. Simple things like this are proving quite difficult, as being such an unusual car, I'm not sure where to put what fluids! I am driving it about once a week, but I suspect that this will be less over the winter months I wondered if any of you guys would have any advice or could point me in the direction of 'Delorean care 101!'. On a separate issue - I don't seem to have any reverse lights. I have check the bulbs which seem fine and I understand that there is no fuse for these lights on an automatic box. Any hints would be greatly welcomed. Many thanks in advance, Steve Thompson vin 1271 Re: Winter Checks - steve.s - 29 Oct 2008 Hi Steve Personally i don't really do much at all. if you don't start for a while disconnect the battery, and you could put some fuel saver in the tank (to stop the petrol turning nasty!) i might buy a bubble, there is a cheaper one for sale in this country, half the price of a carcoon. Phil has an airchamber which seems good, and has a frame with it. Definately worth changing the coolant when it comes out of hibernation, to stop any damage Re: Winter Checks - bozzzydmc - 30 Oct 2008 In my view its more a case of where you store it. A dry garage is where i store mine with a humidifier (set on low) Apart from disconnecting the battery ( which is on a key Switch ) and running the fuel down to a minimum is all I really do to mine. Ive stopped covering it with a car cover. This lets it air rather than trapping any condensation. Some say over inflate the tyres to prevent flat spots. I would check your coolant for age prior to storage but winter is a good time to change all your fluids . Re: Winter Checks - stevieT - 30 Oct 2008 Thanks guys. I have to keep it outside, so I do put a cover over it. I don't have room for a bubble sadly. All the best Steve Re: Winter Checks - Chris Williams - 30 Oct 2008 I still think the best thing you can do is keep the car (and I include any car in this) used over the winter, even if it's off the road just give it a drive every couple of weeks when it's dry weather, operate everything including the Air-con. You should be able to check the anti-freeze with a tester, but if there is any doubt just change it. Chris Re: Winter Checks - bozzzydmc - 30 Oct 2008 stevieT Wrote:Thanks guys. Hi Steve If you do put a cover over it make sure its well tied down, any flapping of it in the wind can cause annoying scratches ![]() Re: Winter Checks - stevieT - 05 Nov 2008 I'll certainly give it a quick once 'round the block every week or so. How do I test the anti freeze?? Thanks again for the help Steve Re: Winter Checks - bozzzydmc - 05 Nov 2008 http://www.workshopsupplies.co.uk/index1.html Whilst it will tell you the effectiveness of the antifreeze it wont show its age... If your unsure of when it was last done or if its more than 2 years old, flush this out and put some fresh stuff in .... I do mine every year anyway... |
