engine cover release handle brocken - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 8 - Frame / Body / Interior (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: engine cover release handle brocken (/showthread.php?tid=1918) |
engine cover release handle brocken - hana 5284 - 11 Oct 2008 Hi all not sure if this is really in the right topic but my engine cover release handle (behind the drivers sholder)LHD seems to have brocken it pulls out quite far i think the end in the cab has brocken or came off.i dont think it is the engine cover end would anyone have a diagram on what it looks like behind the pully and if you know if i will be able to get to it from the cab side. i would appreciate any advice or tips thanks alot Tyson Re: engine cover release handle brocken - Darren C - 11 Oct 2008 ![]() Hope this helps! The best thing to do is take out your near side (drivers LHD) rear light cluster. You can reach in behind the Number plate and release the engine cover. Once open you'll be able to see whats gone wrong and take off the access plate (item 32) to the latch assembly. Good luck Best Regards D Re: engine cover release handle brocken - hana 5284 - 12 Oct 2008 thanks alot darren i will try that hopefully tomorrow great tip about taking out the light thanks alot cheers Tyson Re: engine cover release handle brocken - Rich Hanlon - 20 Oct 2008 Once you've got in, if you need a replacement pull-handle then I think Vehicle Wiring Products (In Nottingham) does an identical pull handle kit. Re: engine cover release handle brocken - hana 5284 - 23 Oct 2008 thanks richard i am still waiting to sort it out just haven't had the time to spend on her yet but thanks for the link kind regards Tyson RE: engine cover release handle brocken - er1c - 09 Jul 2019 It locks Mine never has and I never new it had a locking mechanism on the engine bay I always thought it was a bit insecure... So I have found the handle and that still works and I can hear the latch moving. But it seems to be missing anything which fits into the latch.https://i.imgur.com/CsJ3VNp.jpg https://i.imgur.com/pnoZZi2.jpg https://i.imgur.com/hlKgtFm.jpg Am I right in assuming https://www.deloreango.com/en/engine-cover-latch-striker-insert.html Is the culprit.... ? RE: engine cover release handle brocken - DMC1983 - 09 Jul 2019 You need this... https://www.deloreango.com/uk/engine-latch-striker.html Mine was missing too when i bought my car RE: engine cover release handle brocken - er1c - 09 Jul 2019 (09 Jul 2019, 13:08)DMC1983 Wrote: You need this... Ahhhh Thanks so much that's what screws into the pic with the hole in ? https://i.imgur.com/hlKgtFm.jpg It looks like that may be all I need if the female receiver for that is in there, hard to tell from the pics. RE: engine cover release handle brocken - DMC1983 - 09 Jul 2019 Thats all you will probably need. You wont need to screw it all the way in though, well i didnt anyway. Some adjustment may be required to get it right RE: engine cover release handle brocken - er1c - 09 Jul 2019 Its funny that little latch striker looks strikingly familiar as the pins which hold the base of my Christmas tree in place..... |
