seat belts - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 8 - Frame / Body / Interior (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: seat belts (/showthread.php?tid=1871) |
seat belts - jon.cobby - 12 Sep 2008 Hi there does anybody know where i can get a set of seat belts ,as mine have rips in and its failed the mot. I am thinking that these must be used on another type of car ![]() Kind regards Jon Re: seat belts - Guinney1971 - 12 Sep 2008 not sure off hand what they match up to, but give Dave Howarth a ring as he's got a warehouse full of DeLorean spares and can probably help you out. Re: seat belts - steve.s - 12 Sep 2008 Hi which side you after i did have a spare drivers side, but water has got in my garage and wet it, so will have to check if it still works. would only want a tenner though!/ Regards Steve Re: seat belts - Darren C - 12 Sep 2008 Hi Steve, My belts had lost the spring to retract back onto the bobbin. If your a little handy go down the scrappies get a set of front belts from an Astra Mk111 (4 door). Unstitch the end bracket, slide off the fixings/clip. (do the same to your old belts). Put Delorean clips on to the astra belt and re-stitch your old D bracket on the end. DO A GOOD JOB on the stitching it could save your life one day. Make sure you remember the orientation and order of all the brackets, before you re do the stitching too! The Astra Mk111 bobbin is spot on to the delorean, with the exception of the threaded mounting hole. On the Delorean its not threaded. So basically drill out the thread, and cut the thread boss off. It should fit a treat. And now for the best bit....The label on the Astra MK111 at the end off the belt, that will be seen when fitted says "Made in N. Ireland"! Should cost you around £5 a side, and about 2 hours each. Best of Luck Regards D Allways giving away his secrets! Re: seat belts - jon.cobby - 15 Sep 2008 Hi Steve you offered your spare drivers side seat belt to the other chap for a tenner,if he doesnt want it I would very much like it as my D failed its mot due to my seat belt being frayed.I presume its ten plus postage? Kind Regards Jon. Re: seat belts - Guinney1971 - 15 Sep 2008 following on from what Darren put, if Cavalier belts are the same as Astra Mk3 ones (same era, and many Vxl parts are interchangeable), then we've got a set of those going spare if required. Re: seat belts - jon.cobby - 15 Jun 2009 Thank you all for your replies The problem i had was that the webbing was frayed where it gets caught in the door. I thought it would foul the MOT. Whilst sitting in the car I noticed that the seat belt extends out an awful long way so I cut the first Foot off (which is all that is frayed), then had it professionally sown up. You would never know, job done five quid. Kind Regards Jon... vin no ..10924 Re: seat belts - Guinney1971 - 15 Jun 2009 if it helps, I'm scrapping an Astra Mk3 Estate - do you want the belts off of that? Darren- does it matter if they are front one's or back ones? Re: seat belts - Darren C - 16 Jun 2009 Hi Claire, Front ones. When you re stitch your delorean fittings on, be sure to shorten the belt by 2ft. In the Astra the length of the spare belt when reeled in is longer than the D. (due to the longer distance between floor and pillar points than the D) Kind regards D Re: seat belts - Guinney1971 - 16 Jun 2009 right, well I'll wait for Jon to reply back then about these - but ideally we need to know asap, as the car is being collected by the scrapman this weekend hopefully. Been getting some bits off of it tonight for some of the guys on the Astra Mk3OC, so time is running out for getting any more stuff of of it before it goes to Vauxhall Heaven. Re: seat belts - Rich Hanlon - 25 Aug 2009 Hi folks - resurrecting an old thread. Does anyone know of any seatbelt buckles which would match the Delorean ones exactly? The reason is this - I'm considering making some clips that go around the door striker pins, which would accommodate the existing seatbelt buckle, with a view to using the seatbelt as a barrier to people getting in the car at shows etc. So basically want something to match the part that the seatbelt plugs into in normal operation. Chers, Rich Re: seat belts - Guinney1971 - 25 Aug 2009 hmm....... I always thought the seatbelt buckles were very Leyland-ish, like a Metro or summat? Mind you, you're the BL Geek!! :lol: Is it worth having a rummage down Uncle Albert's? Failing that, theres a mahoosive autojumble at Thoresby Hall on Monday. Re: seat belts - stunned_monkey - 28 Aug 2009 Same as an old Mini. Re: seat belts - Rich Hanlon - 28 Aug 2009 Thanks all! Re: seat belts - Guinney1971 - 29 Aug 2009 Rich, I wouldnt be surprised if Allegro ones weren't the same as (proper) Mini seatbelts, same sort of era after all - is it worth comparing the ones on your car? Seeya Monday, bright and early! lol |
