helicoil in block - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: GENERAL DELOREAN DISCUSSION (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=2) +--- Forum: General Discussions on the DOC / Car / Company / JZD (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=25) +--- Thread: helicoil in block (/showthread.php?tid=1729) |
helicoil in block - Tourettes Tony - 12 Jul 2008 hi all has anyone had to helecoil the block for the head bolts i have a couple what are a bit suspect and would like them all done thanks tt - Tourettes Tony - 16 Jul 2008 found the heli-coils sizes are m12 x 1.75 just for everyones info TT - NickT - 16 Jul 2008 You don't seem to be having much luck ! Either that or you just want to be sure ![]() NickT - Tourettes Tony - 16 Jul 2008 i know nick i made a mistake and i have no problem admitting it, the head bolts have to be oiled up before instalation before you torque up, a useful bit of info in case anyone has the pleasure of an engine rebuild. But at least i will have 2 running engines one with turbo one without, so i worked out i might be able to install both and get some decent power :lol: TT |
