Replacing Power Window Glass - what's the glue to use? - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 8 - Frame / Body / Interior (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Replacing Power Window Glass - what's the glue to use? (/showthread.php?tid=167) |
Replacing Power Window Glass - what's the glue to use? - Barson - 30 Nov 2006 As title. I need to re-attach the glass of my power window to the window carrier. Does anyone know what adhesive I should use? Is it the polyurethane like all the other windows? Has anyone had any experience in this procedure? The tech manual seems to ignore this. :oops: cheers! Dave. - bozzzydmc - 30 Nov 2006 PU Adhesive / Tiger seal will be good Just mind those nasty sharp SSteel edges inside the door. Recommend you stick 'duct tape' around them (leave it on for next time when you have finished ) - Barson - 30 Nov 2006 cheers bozz yet again
- bozzzydmc - 30 Nov 2006 no problem bars
- Guinney1971 - 01 Dec 2006 is there anything that cant be fixed with Tiger Seal? :lol: Claire - stunned_monkey - 01 Dec 2006 Our silicone outer door seals won't stick to it. - bozzzydmc - 01 Dec 2006 We had a metal sign stuck to some brickwork with it at work. When the sign had to come down it ripped all the facings off the brickwork. Strong stuff....... |
