strange indicator fault - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 3 - Electrical (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=15) +--- Thread: strange indicator fault (/showthread.php?tid=1631) |
strange indicator fault - steve.s - 09 Jun 2008 Hi All Vin 1621 back on the road again with a rebuilt front caliper. did it myself to make sure of a good job!. now the indicators have packed in. occassionally work, but most of the time nothing..no click etc. but the hazards work fine. do these feed through the same earth?. i know first will be the fuse to see if its ok or dirty contacts. next the column connection and switchgear. anyone else had this fault? - bozzzydmc - 09 Jun 2008 Check the electrical connector block is correctly seated on the back of the hazard warning switch matey. - Glen & Sam - 09 Jun 2008 hi mine does the same its ullsay a dry joint in the relay box behind the dash in the driver side i have done mine 3 times know but i going to buy a new one - steve.s - 09 Jun 2008 thanx all will check is it like an mx5 i had...if you remove the hazard switch then the indicators were dead....it seemed to take a feed of this switch. just wondered if the D is the same?. Regards - Glen & Sam - 09 Jun 2008 yep its works i think the same way as i can remember doing it to mine when ikind of had a melt down poblem with mine :roll: |
