Exhaust Gaskets M7 Studs and Nuts - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 1 - Engine (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=13) +--- Thread: Exhaust Gaskets M7 Studs and Nuts (/showthread.php?tid=1556) |
Exhaust Gaskets M7 Studs and Nuts - bozzzydmc - 14 May 2008 Has anyone got a good source for these pieces please Regards Mike - Dan6457 - 14 May 2008 Does this mean your custom stainless system has arrived? exhaust - Darren C - 14 May 2008 Try DMCH, Items 18 & 20 on Engine Exhaust parts list, Studs $1.99 each (a quid) Gaskets $9.99 each (a fiver) Even with tax that's cheap as chips and original DMC stock. Best Regards D Re: Exhaust Gaskets M7 Studs and Nuts - Chris Williams - 14 May 2008 bozzzydmc Wrote:Has anyone got a good source for these pieces please If it's any good to you I have a few S/H ones you can have. Chris - bozzzydmc - 14 May 2008 ![]() Is part 18 the m7 stud or one of the m10 studs that holds the cross over pipe ?? Not sure thats the right one but buggered if i can see 12 no studs on the page - bozzzydmc - 14 May 2008 Dan1986 Wrote:Does this mean your custom stainless system has arrived? Will be here soon just trying to be prepared
- Chris Williams - 14 May 2008 Thats the M10 one, the M7 ones are part no; 102167 Chris M7 stud - Darren C - 14 May 2008 Sorry Mike, Its item 48 on the cylinder head page. Number as per chris's post. Sill cheap at $3.95 (2 quid) Best Regards D - NickT - 15 May 2008 I think the exhaust studs are different threaded, m7 to engine block and m10 for manifold nuts. Item 18 in diagram. NickT - Chris Hawes - 15 May 2008 I would recommend 4 studs per port as you don't want any leaks... I'm talking from experience although my system is a different design. - Guinney1971 - 15 May 2008 I'm trying to remember where mine came from - I *think* they came from KMI in London as part of all the headgasket kit - I'm pretty sure they relate to a Volvo 760 anyway, so it might be worth having a word with your local Volvo specialist/dealer perhaps??? - Chris Williams - 15 May 2008 ![]() Mike, on the right are the manifold to cross over pipe studs (M10) on the left are the Head to manifold studs (M7) 102167 Chris |
