Brake Master Cylinder question - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 6 - Brakes / Wheels / Tyres (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: Brake Master Cylinder question (/showthread.php?tid=1516) |
Brake Master Cylinder question - Barson - 26 Apr 2008 there's a gasket between the master cylinder and the servo unit - what does it do? it's just that the gasket is of a particular shape and if i replace it with a standard o-ring what would that do? The vacuum is contained in the servo and the brake fluid is contained in the cylinder is that not right?? any help would be appreciated Dave. - Bandit - 26 Apr 2008 Yeh, it does'nt really do much. Its to stop muck getting in rather than anything getting out, would'nt really be an issue if you did not fit one. - Barson - 26 Apr 2008 yeah. good point about the muck I'll be sticking two o-rings on it just to create some kind of seal. cheeers! Dave. |
