Headlamps: I have a leak - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 3 - Electrical (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=15) +--- Thread: Headlamps: I have a leak (/showthread.php?tid=1466) |
Headlamps: I have a leak - Barson - 08 Apr 2008 Hello my Delorean chums On operation of the dip headlights (that's two pushes of the dip headlight switch on the centre console) I get the dip (as it should be) AND, for some reason, a dim light coming from the H1 inners also a light from the main beam telltale (blue bulb - instrument panel). The power isn't coming from the main beam relay because I've tested it by removing the relay an operating the dip beams - i have the same result. the power might be coming from the dip beam circuit - but where? I suppose i should test to see whether I'm getting power to the inners by test removing the outer bulbs or the telltale on the panel...didn't think of that. any ideas? Dave. - Dodgy Motor - 08 Apr 2008 is this after you have wired the fog warning light to the lamda light? if not check the earth of the dipped head lights ![]() - Barson - 08 Apr 2008 haven't touched the fog light yet. thanks - I'll check that ![]() - NickT - 09 Apr 2008 Did you change the wiring in the socket to make the lamps compatible with H4 bulbs? If not then the earth path will be through other lamps filament. I have a couple of converters that were given to me but I'd already re-wired the lamps (not using Scotchlocks!) NickT - Barson - 09 Apr 2008 well that was my initial though either that it was leaking back through the bulb itself or through the telltale bulb. what did the convertors consist of? so i can understand whay they're doing ![]() I could remove the blue/white wire from the back of the conector on the H4 bulb, but that' leav me with no main beam outer. - Barson - 09 Apr 2008 i could stick a couple of fat diodes in there i suppose... - NickT - 09 Apr 2008 Or wire it correctly ![]() NickT - Barson - 10 Apr 2008 sorted. so there. I'm off now to get my electrical engineering degree off ebay. see you in the morning my delorean chums. :lol: - NickT - 11 Apr 2008 Nice one ![]() I just dug out the converters from the garage this morning tel tell you which wires to swap ! Well done Barson B.Sc ![]() NickT |
