Sticking Solutions - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 8 - Frame / Body / Interior (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Sticking Solutions (/showthread.php?tid=1278) |
Sticking Solutions - Paul McKay - 28 Jan 2008 The black plastic edging on the hood is starting to come away at one edge, i have tried re-fixing with impact adhesive, but its not sticking. Any solutions would be greatly appreciated. - TheOriginalMrP - 28 Jan 2008 Try Tiger seal Paul, Clean surfaces well, apply a small amount on 1 surface, apply, and leave taped with masking tape overnight...... - Paul McKay - 28 Jan 2008 Thanks for that. Can you tell me where to get it please, and how is it applied? Does it just squeeze out of a tube, or more like silicone with a skeleton gun? - stunned_monkey - 28 Jan 2008 There is a self-adhesive U-channel heat shrink available from RS and Farnell which does a superb job of replacing the original glued on stuff... will have to track down the part number tho... Tiger Seal is just another name for Sikaflex. It's black polyurethane adhesive, bought by the cartridge. I get it from Wurth under the name Bond & Seal (gotta love the German does-what-it-says-on-the-tin approach to naming a product!) - Tourettes Tony - 28 Jan 2008 most places do it car shops mainly, and if you can find any other use for it use it, it does go off quick its in a tube the same as silicon hope this helps tony TT ps its about a tenner a tube
- TheOriginalMrP - 28 Jan 2008 Tourettes Tony Wrote:ps its about a tenner a tube Unless of course you go into a pound shop and get some "No more nails" That stuff is jet black too, and although it seems like a builders product as apposed to a motorist's sealant, its virtually the same, only without the flexibilty, which won't be necessary for that application.... Don't all call me a cowboy at once, I'm good at preaching the cheap alternatives, but never use them myself! LOL Ben - Paul McKay - 29 Jan 2008 Thanks for the replies guys. |
