Are there any adjustments i should make to the car after.... - Printable Version
+--- Thread: Are there any adjustments i should make to the car after.... (/showthread.php?tid=118)
Are there any adjustments i should make to the car after.... - Craig Churchill - 06 Nov 2006
i fit the cat bypass?
or is it just bolt on and go!!!
and
What difference should i notice and why?
a curious
Craig
Vin 16273
- NickT - 06 Nov 2006
should be fit and forget.
you should get some more power out of the engine because there is no back pressure caused by the small bore monolith in teh catalytic converter.
you could always check our fuel mixture at a garage to double check.
disconnect oxygen sensor, set fuel mixture to 1 to 1.5% CO at idle
reconnect oxygen sensor, level should be about 1% or less
rough guide but it could save fuel if too rich.
nickt.
