VIN No. 1867 - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: GENERAL DELOREAN DISCUSSION (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=2) +--- Forum: Members Cars (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=40) +--- Thread: VIN No. 1867 (/showthread.php?tid=6177) |
RE: VIN No. 1867 - Justwatching - 30 Apr 2023 Replacing weather seals is on my to-do list this year. I've started with the one attached to the door. With the old one off, I noticed the drain holes for the door don't align with the slots in the metal strip that secures the rubber blade. Two additional holes have been made to facilitate drainage. [attachment=1433] Are all DeLoreans like this, or is this a factory bodge for early cars? I doubt my car has had enough usage in its life for the weather seals to have been replaced by someone before now, so I doubt it's an owner work-around. RE: VIN No. 1867 - theningiachicken - 30 Apr 2023 (30 Apr 2023, 16:04)Justwatching Wrote: Replacing weather seals is on my to-do list this year. I've started with the one attached to the door. I did notice something very similar when i replaced mine a few months back, very bizzare that they didn't line up so they had to "modify" the holes RE: VIN No. 1867 - Justwatching - 02 May 2023 Got the door marker lights working. The plunger switch in the door shut had been disconnected on each side. Love an easy fix! [attachment=1434] However... A buzzer sounds continuously when the driver door is open. No lights on, no key in the ignition. I'm pretty sure that isn't right. Can anyone give me a steer on that? RE: VIN No. 1867 - Rissy - 03 May 2023 That's normal operation from the Buzzer box above the steering column. Unplug it. This is also normal procedure for the owner.
RE: VIN No. 1867 - Rich Hanlon - 03 May 2023 Oh that thing's dreadful, probably explains why someone disconnected the door open switch! RE: VIN No. 1867 - Justwatching - 03 May 2023 (03 May 2023, 08:14)Rissy Wrote: That's normal operation from the Buzzer box above the steering column. Unplug it. This is also normal procedure for the owner. Thanks for confirming. What a terrible design though; it's annoying, doesn't alert the user to anything important, and forces one of the car's most notable features to remain closed. On the plus side, I don't have to fix anything. RE: VIN No. 1867 - Justwatching - 29 Aug 2023 New fuel lines installed ready for the trip down to the Morgan factory in a couple of weeks. Well, minus the return line - it put up too much of a fight. It was a pig to start and ran rough initially, but took it for a drive and everything seems to have settled. [attachment=1461] RE: VIN No. 1867 - Rich Hanlon - 30 Aug 2023 Great job, they can be a nightmare I found the fuel filter one to be the most disproportionately difficult one for a simple design its pretty difficult to access! RE: VIN No. 1867 - Chris Williams - 30 Aug 2023 Quote:Well, minus the return line - it put up too much of a fight.I bet a pound you struggled disconnecting it from the hard line...........
RE: VIN No. 1867 - Justwatching - 02 Sep 2023 (30 Aug 2023, 20:10)Chris Williams Wrote:Quote:Well, minus the return line - it put up too much of a fight.I bet a pound you struggled disconnecting it from the hard line........... Of course. Penetrating fluid didn't make a difference and I didn't want to use a blowtorch for obvious reasons. RE: VIN No. 1867 - Justwatching - 02 Oct 2023 Got my fuel flap back from repair. Looks much better without the pot-rivets! Used a general purpose contact adhesive. We'll see how well that holds up. Please excuse the finger prints/marks. The picture was taken immediately after installation. [attachment=1474] [attachment=1476] [attachment=1475] RE: VIN No. 1867 - Rissy - 02 Oct 2023 Excellent work! Looks OEM now! RE: VIN No. 1867 - Guinney1971 - 09 Oct 2023 Looks great! RE: VIN No. 1867 - Justwatching - 12 Nov 2023 Got given a key replicator. I know, unusual, but no gift horses were looked in the mouth and I got to work trying to make a spare door key. [attachment=1480] I used a WB2 key blank. Not sure if this is best/correct, it seemed to be the closest thing I could find. [attachment=1481] The result was...a bit off; the sides were slightly out of phase with each other. Surprisingly, it worked fine on both doors. [attachment=1482] I've got a second blank, so I'll have another go and try for something neater. RE: VIN No. 1867 - Guinney1971 - 13 Nov 2023 excellent stuff, a neat gadget to have. |
