VIN#6126 Chassis restoration - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: GENERAL DELOREAN DISCUSSION (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=2) +--- Forum: Members Cars (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=40) +--- Thread: VIN#6126 Chassis restoration (/showthread.php?tid=6008) |
VIN#6126 Chassis restoration - Rich Hanlon - 28 Feb 2020 I got them from DeLorean Go but you could make some by tapping M7 down some 1/2" brass hex bar. The studs were fairly long. I think the main advantage of brass is that you can always undo them. Obviously it's softer than steel so if it's engaged on more threads it spreads the load over more threads making the studs less liable to be damaged. The other advantage I suppose of a longer nut fully covering the stud, is that the normally exposed surface of the stud outside of the nut, which is usually prone to corrosion, making it difficult to get the nut past them ( leading to damaged studs) - is now fully covered by the elongated nut, therefore less likely to corrode. So you don't have to turn the nuts past/ over a big blob of rust. I have a mixture of studs but they're now all good. Two specials, made to fit some oversized holes, some of Eds which I had forgotten I had in stock, and a couple of DeL Go ones. Sent from my moto g(7) power using Tapatalk The surface corrosion has been fairly rapid since I had the epoxy stripped, certainly. The rough surface it leaves oxidises very rapidly. But all the soft stuff is now cut out, and it's going to be stripped off again before galvanising [emoji846] Hard to believe it's the same frame as this from November!![attachment=755] Sent from my moto g(7) power using Tapatalk RE: VIN#6126 Chassis restoration - Chris P - 28 Feb 2020 That surface rust is absolutally nothing to worry about......it would be if you left the cassis in a very damp place for a long time. But I don't think that will be happening! If you are having it galvanised the pre-cleaning process should sort it out. VIN#6126 Chassis restoration - Rich Hanlon - 28 Feb 2020 Thanks Chris[emoji106] Yeah, it'll be fine. It didn't help that I had to transport it on a wet day after it had been dipped. But yes that'll all be off before it has it's nice hot bath [emoji16] Sent from my moto g(7) power using Tapatalk VIN#6126 Chassis restoration - Rich Hanlon - 11 Mar 2020 Galvanised...[attachment=763] Sent from my moto g(7) power using Tapatalk And Powder coated...[attachment=764] Sent from my moto g(7) power using Tapatalk RE: VIN#6126 Chassis restoration - Chris P - 11 Mar 2020 That looks like a proper job! Well done Richard! VIN#6126 Chassis restoration - Rich Hanlon - 11 Mar 2020 Thanks! Can't wait to see it - collecting on Friday all being well [emoji846] Sent from my moto g(7) power using Tapatalk RE: VIN#6126 Chassis restoration - Chris Williams - 11 Mar 2020 Looks lovely, I'm sure you cant wait to start re-building it now. Chris VIN#6126 Chassis restoration - Rich Hanlon - 12 Mar 2020 Too right, better start soon while I can still remember how it goes together!! Sent from my moto g(7) power using Tapatalk RE: VIN#6126 Chassis restoration - Stuart Rees - 12 Mar 2020 6237 needs the same treatment, which company did the galvanise and powder coating? VIN#6126 Chassis restoration - Rich Hanlon - 12 Mar 2020 Hi Stuart, that is BMT in Gt. Yarmouth [emoji846] Sent from my moto g(7) power using Tapatalk Pre powder coating... [attachment=766] Sent from my moto g(7) power using Tapatalk VIN#6126 Chassis restoration - Rich Hanlon - 13 Mar 2020 .[attachment=767] Sent from my moto g(7) power using Tapatalk RE: VIN#6126 Chassis restoration - Chris P - 14 Mar 2020 Nice shot of Caster Lifeboat Station Richard....we are often in that neck of the woods.....Chassis looks great....
VIN#6126 Chassis restoration - Rich Hanlon - 14 Mar 2020 Well identified!! Here's a few more from this morning:[attachment=768][attachment=769][attachment=770][attachment=771][attachment=772] Sent from my moto g(7) power using Tapatalk VIN#6126 Chassis restoration - Rich Hanlon - 17 Mar 2020 Here we begin. First step cleaning out and retapping all the threaded holes on the chassis... I'm reaming out the upper suspension mounts to 0.5"[attachment=775][attachment=776] Sent from my moto g(7) power using Tapatalk RE: VIN#6126 Chassis restoration - Chris P - 18 Mar 2020 Its only major downside Richard, your car is going to last FOR EVER!! Well done again. |
