Starter problems - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: DELOREAN HELP AND ADVICE & PARTS CROSS REFERENCE (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=4) +--- Forum: 2 - Emission / Fuel Systems (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Starter problems (/showthread.php?tid=1314) Pages:
1
2
- Carl Hammond - 16 Mar 2008 Hey Barson, Sorry, I wasn't being very specific there! :oops: What I meant was, there was a mix of water/fuel in that hole in the black rubber casing, should it be as far up as that? I've taken a pic just now (see below). Thanks for the great tips matey. ![]() [/img]Kind regards - Carl Hammond - 16 Mar 2008 Hi Alistair, Well, my car has sat for a considerable amount of time between previous owners, so I wouldn't at all be surprised if the connectors aren't making the right contact. Bit surprised about the fuel pump itself though, as the previous owner purchased a new one in 2003? Not sure how much life they have, but if the car stood for most of that time then it's possible it's on the way out. Besides, I'm sure I have heard other owners say they usually carry a spare fuel pump "just in case" ! Cheers for your help bud. Kind regards - Barson - 16 Mar 2008 hi the top of the pump looks abit worse for wear there. ![]() Do you have a rubber boot that fits over the pump where you're viewing it from something like this: ![]() if there isn't one, then that might explain the rust and the intermittent connection and the liquid build up. If there's fuel collecting in the boot as you look down the side of the fuel pump, then it could be that the metal clip holding the fuel pump securly to the boot is not as tight as it should be (this is the clip that's around the boot - you'll be able to see it if you lift the boot and pump out of the tank). on the other hand it could be that your bango fittings are leaking (but i haven't heard of an instance of this - anyone else?) If that was mine, I'd replace the connectors on the wires, fuel pump, bango fittings and flexible hoses (and pick up filter).
- NickT - 16 Mar 2008 Re-make the electrical connectors to the fuel pump as what Barson suggests. Ideally battery voltage should be 12.5v. With key in position 2, fuel pump relay should run the fuel pump to prime the system. Once done start engine without touching the accelerator. Regards, NickT. - tc ozzie - 17 Mar 2008 could you hear the pump running when ya had the problem is the relays clicking and no pump noise that looks like that pump needs changing that dont look like its been changed in a while i changed my battery and alternator and starter and fuel pump about a few weeks into geting mine its been fine ever scince i had that problem go out in morning starts fine come back its fine but when you go out about 5 mins after a run slow or no starting like the batterys gone flat or constant turning over but no fireing could be lots of things the only thing still needs changing on mine is the fuel accumalator but thats a job for p js do check all connections also that dont help if ya got bad earths or loose wires everywere best to check everything i stil keep finding things with mine there propper strange motors - Carl Hammond - 17 Mar 2008 Thanks guys, Well by the looks/sounds of it I might as well get the whole kit now and replace all those worn originals in one go. My car didn't even have the rubber boot and I can already see how crucial that part is! Time to call PJ Grady! ![]() Cheers - tc ozzie - 17 Mar 2008 yeah call p j gray or go deloreans direct for your bits either way it gott to be done those damn old bits time to renew them all go for it.......
