VIN No. 1867 - Printable Version +- The DeLorean Owners Club UK Forum (http://www.deloreans.co.uk/forum) +-- Forum: GENERAL DELOREAN DISCUSSION (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=2) +--- Forum: Members Cars (http://www.deloreans.co.uk/forum/forumdisplay.php?fid=40) +--- Thread: VIN No. 1867 (/showthread.php?tid=6177) |
RE: VIN No. 1867 - Rich Hanlon - 05 Mar 2024 Bravo!! RE: VIN No. 1867 - Rissy - 05 Mar 2024 Nice! Excellent work. Looks nice and clean! Lube it up on the return path (including bolt shafts of Y-Pipe). I’m sure it’ll never be as bad as that again. RE: VIN No. 1867 - Chris P - 05 Mar 2024 is that a helicoil? RE: VIN No. 1867 - Justwatching - 13 Mar 2024 Thanks for words of support everyone. It has been (and continues to be) a testing experience. And yes, it's a helicoil. I got everything reassembled at the weekend and had the car running briefly. I was looking for coolant leaks but found an ATF leak instead. It's those bloody transmission cooler lines I changed! So, it looks like the replacement lines need additional washers. DeLoreanGo say the washers are "not shown on the parts diagram" which I don't think is the fully story - they're not shown because they aren't on the original lines! RE: VIN No. 1867 - Justwatching - 26 Mar 2024 Update on 1867: washers installed on the transmission cooler lines - no more ATF leaks. Since then, it developed two separate coolant leaks, both resolved by simply tightening the clamp. My experience of the silicon hoses so far is that they're easy to work with, but don't seal as well as rubber. Luckily both leaks were accessible, but I'm nervous about the same happening in the valley. I might cry if I had to take it all apart again! Adjusted up the handbrake which was worthwhile. The handbrake has always been naff, which is especially noticeable on an automatic. It's still not great, but I'm happy to take a no-cost improvement. RE: VIN No. 1867 - theningiachicken - 26 Mar 2024 (26 Mar 2024, 10:30)Justwatching Wrote: Update on 1867: washers installed on the transmission cooler lines - no more ATF leaks. i need to spend some more time adjusting my handbrake too, dont like how my car is held with the transmission in park, think my cables are due to be replaced as they hardly move the pads with max adjustment
RE: VIN No. 1867 - Chris Williams - 26 Mar 2024 Check to see that the machanism at the pull handle end is all OK, sometimes the bracketry fractures. RE: VIN No. 1867 - theningiachicken - 27 Mar 2024 (26 Mar 2024, 21:21)Chris Williams Wrote: Check to see that the machanism at the pull handle end is all OK, sometimes the bracketry fractures. think my bracket is all okay, the cables never seemed to have much movement left in them when they were setup last time. i'll probably take it all apart again and attempt again and get new cables |
